Atmel SAM4S RTOS Demo
SAM4 microcontroller from Atmel
This page documents a FreeRTOS demo application for the SAM4S ARM Cortex-M4 microcontroller from Atmel. The demo uses the FreeRTOS GCC ARM Cortex-M3/4 port, the free Atmel Studio 6 IDE, and components of the comprehensive Atmel Software Framework (ASF). The project is pre-configured to run on the SAM4S-EK evaluation kit.
IMPORTANT! Notes on using the FreeRTOS SAM4S demo project
The Atmel Studio 6 Solution file for the ATSAM4S demo application is called RTOSDemo.atsln, and is located in the FreeRTOS/Demo/CORTEX_M4_ATSAM4S_Atmel_Studio directory.
If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0 (see the functionality section below), then the demo will include the standard com test tasks. The standard demo com test creates two tasks - a Tx task that sends characters to the USART, and an Rx task that expects to receive every character sent by the Tx task. A loopback connector is required on the USART port for this mechanism to work - simply link pin 2 to pin 3 on the 9 way connector marked "USART" on the SAM4S-EK.
It should be noted that the com test tasks are included to demonstrate queues being used to communicate between tasks and interrupts, and to demonstrate a context switch being performed from inside an interrupt service routine. The serial driver used is not intended to represent an efficient implementation. Real applications should make use of the USART's peripheral DMA channel (PDC).
    The queue receive task is implemented by the prvQueueReceiveTask() function in main_blinky.c. It repeatedly reads from the queue with a block time specified, causing it to enter the Blocked state if the queue is empty. The task toggles the red LED each time the value 100 is received from the queue, therefore, because the queue send task sends to the queue every 200 milliseconds, the queue receive task should exit the Blocked state and toggle the red LED every 200 milliseconds.
A 'check' software timer is created that periodically inspects the standard demo tasks to ensure all the tasks are functioning as expected. The check software timer's callback function toggles the green LED on the SAM4S-EK hardware. This gives visual feedback of the system health. If the green LED is toggling every 3 seconds, then the check software timer has not discovered any problems. If the LED is toggling every 200 milliseconds, then the check software timer has discovered a problem in one or more tasks. This mechanism can be tested by removing the loopback connector, and in so doing, deliberately causing the com test tasks to fail.
CreateProjectDirectoryStructure.bat is located in FreeRTOS/Demo/CORTEX_M4_ATSAM4S_Atmel_Studio, and must be executed before the demo application can be built successfully.
  2. Open FreeRTOS/Demo/CORTEX_M4_ATSAM4S_Atmel_Studio/RTOSDemo.atsln from within the Atmel Studio IDE.
  5. Select 'Build Solution' from the IDE's 'Build' menu, the RTOSDemo project should build without any errors or warnings.
  6. After the build completes, select "Start Debug and Break" from the IDE's Debug menu to program the SAM4S microcontroller flash memory, start a debug session, and have the debugger break on entry into the main() function.
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_M4_ATSAM4S_Atmel_Studio/src/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
