Infineon XMC4500 ARM Cortex-M4 Floating Point Demo
Using the Tasking VX-Toolset for ARM development tools
XMC4500 microcontroller development board programmed with the Tasking VX Toolset for ARM
This page documents a FreeRTOS demo application for the XMC4500 ARM Cortex-M4 microcontroller from Infineon. The demo uses the FreeRTOS Tasking VX-toolset ARM Cortex-M4F port, which requires the application to enable the ARM Cortex-M4 hardware floating point unit, and the project options to be configured to generate floating point instructions (the project described on this page is already configured correctly).
IMPORTANT! Notes on using the FreeRTOS/Tasking XMC4000 demo project
The Tasking VX-toolset Eclipse project file for the XMC4500 demo application is located in the FreeRTOS/Demo/CORTEX_M4F_Infineon_XMC4500_Tasking directory. The Preparing the Eclipse Project section of this page contains important information on setting up the demo project directory, and importing the demo project into the Tasking Eclipse IDE.
The Infineon ARM Cortex-M4 Demo Application
Two configurations can be selected between using the mainCREATE_SIMPLE_BLINKY_DEMO_ONLY constant, which is located near the top of main.c.
When mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 1, main() calls main_blinky(), which then creates a very simple demo, as described below.
When mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0, main() calls main_full(), which then creates a comprehensive test and demo application, which demonstrates:
  • Software timers.
  • Queues.
  • Mutexes.
  • Semaphores.
Some of the created tasks are from the set of standard demo tasks, while others are specific to the XMC4500 Tasking demo. Standard demo tasks are used by all FreeRTOS ports and demo applications. They have no specific functionality, and are created just to demonstrate how to use the FreeRTOS API, and test the FreeRTOS port.
A 'check' software timer is created that periodically inspects the standard demo tasks, and register test tasks, to ensure all the tasks are functioning as expected. The check software timer's callback function toggles the single user LED on the XMC4500 Hexagon development kit CPU board. This gives a visual feedback of the system health. If the LED is toggling every 3 seconds, then the check software timer has not discovered any problems. If the LED is toggling every 200 milliseconds, then the check software timer has discovered a problem in one or more tasks.
Preparing the Tasking VX-Toolset Eclipse project directory
Eclipse projects can be either standard makefile projects, or managed make projects. The FreeRTOS Tasking ARM Cortex-M4F project uses a managed make project. This in turn means that either:
Option 1 is used for this demo. Therefore, the directory FreeRTOS/Demo/CORTEX_M4F_Infineon_XMC4500_Tasking contains a batch file called CreateProjectDirectoryStructure.bat that copies all the required FreeRTOS source files, and some standard demo application files, into sub directories inside the demo project directory.
CreateProjectDirectoryStructure.bat must be executed before the Tasking project is imported into the Eclipse workspace.
CreateProjectDirectoryStructure.bat cannot be executed from within the Tasking IDE.
Importing the demo application into the Tasking Eclipse workspace
  1. Select "Import" from the Tasking "File" menu. The dialogue box shown below will appear. Select "Existing Projects into Workspace".
  2. In the next dialogue box, select FreeRTOS/Demo/CORTEX_M4F_Infineon_XMC4500_Tasking as the root directory. Then, make sure the RTOSDemo (rather than "FreeRTOS-Simple-Demo", as depicted below) project is checked in the "Projects" area, and that the Copy Projects Into Workspace box is not checked, before clicking the Finish button (see the image below for the correct check box states).
    Selecting the ARM Cortex-M4 RTOSDemo for importing into Tasking Eclipse
    as depicted), and "Copy projects into workspace" is not checked
  1. Ensure the CreateProjectDirectoryStructure.bat batch file has been executed, that the project has been imported into the Tasking workspace, and that mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to generate the required demo functionality, as noted above.
  3. Select 'Build All' from the IDE's 'Project' menu, the RTOSDemo project should build without any errors or warnings.
  4. After the project has built, click the "Debug" speed button in the IDE to program the microcontroller flash memory, and start a debug session.
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_M4F_Infineon_XMC4500_Tasking/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
