NXP LPC1768 ARM Cortex-M3 LPCXpresso Demo
[Embedded Ethernet Examples]
NOTE: This demo was created with the Red Suite IDE. NXP have since acquired Code Red's technology and now the demo can instead be used with NXP's LPCXpresso IDE.
The demo presented on this page is pre-configured to run on the RDB1768 evaluation board from Code Red (Code Red have since been acquired by NXP). The board was fitted with an LPC1768 Cortex-M3 microcontroller from NXP.
The demo uses:
  • The Red Suite Eclipse based IDE from Code Red (now the LPCXpresso IDE from NXP as noted at the top of this page) - which includes the FreeRTOS state viewer plug-in as standard. An Eclipse 'managed make' project is used.
A Red Probe debug interface is built onto the RDB1768 so no additional debug interface hardware is required.
The Red Suite project for the LPC1768 demo is located in the FreeRTOS/Demo/CORTEX_LPC1768_GCC_RedSuite directory. This is the directory to select when importing the project into your Red Suite workspace.
The easiest way to use an Eclipse managed make build is to locate the required build files (C source files, header files and linker scripts) under the directory that contains the Eclipse project file. FreeRTOS/Demo/CORTEX_LPC1768_GCC_RedSuite/CreateProjectDirectoryStructure.bat is a batch file that will copy the required files from their normal locations within the FreeRTOS directory structure to sub directories under the Eclipse project directory. The batch file must be executed prior to attempting a build.
Execute CreateProjectDirectoryStructure.bat from either a command prompt or Windows explorer. It cannot be executed successfully from within the Eclipse environment itself.
  2. Within the Red Suite IDE, select 'Import...' from the 'File' menu.
  3. A dialog box will appear. Select 'Existing Projects Into Workspace', then click 'Next'.
  4. Browse to and select the FreeRTOS/Demo/CORTEX_LPC1768_GCC_RedSuite directory to complete the import process. Take care that the 'Copy projects into workspace' check box is NOT checked during this last step.
Web server configuration
Connect the RDB1768 development board to a computer running a web browser either directly using a point to point (crossover) cable, or via a Ethernet switch using a standard Ethernet cable.
The IP address used by the demo is set by the constants configIP_ADDR0 to configIP_ADDR3 within the file FreeRTOS/Demo/CORTEX_LPC1768_GCC_RedSuite/src/FreeRTOSConfig.h. The MAC address and net mask are configured within the same header file.
The IP addresses used by the web browser computer and the RDB1768 development board must be compatible. This can be ensured by making the first three octets of both IP addresses identical. For example, if the web browser computer uses IP address 192.168.100.1, then the development board can be given any address in the range 192.168.100.2 to 192.168.100.254 (barring any addresses already present on the network).
  1. Open main.c and search for a line that starts "#error". Delete the line (it provides instructions on setting up the directory structure for those using the project without first reading these instructions).
  • Connect the RDB1768 to the host computer using the Debug USB port. This both powers the target and provides a debug interface.
  • To build the project, simply select 'Build All' from the 'Project' menu. The application should build with no errors or warnings (assuming the #error statement has been removed).
  • A launch configuration needs to be created before a debug session can be started. This only needs to be done once, after it has been created debug sessions can be started simply by clicking the 'Debug' speed button. To create a launch configuration first select 'Open Debug Dialog...' from the 'Run' menu.
  • In the dialog box that opens, double click where it says 'C/C++ MCU Application' to create a new configuration. The configuration parameters will be set automatically.
  • Finally click 'Debug' to program the MCU flash memory and start a debug session.
  • Setting up the launch configuration
    The demo application creates 36 tasks prior to starting the RTOS scheduler. These tasks consist predominantly of the standard demo application tasks (see the demo application section for details of the individual tasks). Their only purpose is to test the RTOS kernel port and provide a demonstration of how to use the various API functions.
    • uIP task
    • USB task
    • LEDs 2, 3 and 5 are under the control of the standard 'flash' tasks. Each will toggle at a different but fixed frequency.
    • The USB device port of the RDB1768 will enumerate as a CDC class device. To use the USB port (assuming a Windows host computer):
      1. Connect the RDB1768 to your host computer using the USB device port of the RDB1768 (marked J11).
      2. The host computer should recognise the new USB connection and prompt for the location of a suitable .inf file. Select the option to manually select the .inf file location, then browse to usbser.inf which is located in the FreeRTOS/Demo/CORTEX_LPC1768_GCC_RedSuite directory. Assuming usbser.sys is available on your host computer the CDC device will be assigned a COM port number. The Windows Device Manager can be used to ascertain the actual number assigned.
    Served Web Pages
    The served IO page
    The IO page provides a simple interface that permits data to be sent to an LED. The check box permits the state of the user LED to be both set and queried. Changes are sent to the target hardware by clicking the "Update IO" button.
    Configuration items specific to these demos are contained in FreeRTOS/Demo/CORTEX_LPC1768_GCC_RedSuite/src/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
    Unlike most ports, interrupt service routines that cause a context switch have no special requirements and can be written as per the compiler documentation. The macro portEND_SWITCHING_ISR() can be used to request a context switch from within an ISR. An example interrupt service routine called vEMAC_ISR() is provided in FreeRTOS/Demo/CORTEX_LPC1768_GCC_RedSuite/src/webserver/emac.c. This should be used as a reference example.
    Set the definition configUSE_PREEMPTION within FreeRTOS/Demo/CORTEX_LPC1768_GCC_RedSuite/src/FreeRTOSConfig.h to 1 to use pre-emption or 0 to use co-operative.
