ARM Cortex-M33 (ARMv8-M) Keil Simulator Demo
Using Keil uVision IDE
This page documents a pre-configured FreeRTOS project that targets the Keil uVision ARM Cortex-M33 Simulator and uses the armclang compiler to build the FreeRTOS ARMv8-M GCC port. The project demonstrates using the ARM Cortex-M33 TrustZone and the ARM Cortex-M33 Memory Protection Unit (MPU).
  1. Source Code Organization
The project file for this demo is located in the FreeRTOS/Demo/CORTEX_MPU_M33F_Simulator_Keil_GCC directory and is named FreeRTOSDemo.uvmpw. This Keil multi-project workspace contains two projects - one for the secure side of the ARM Cortex-M33 core, and one for the non-secure side. The FreeRTOS ARMv8-M Cortex-M33 port files compiled in these two projects are organized as follows:
  1. TrustZone Demo
TrustZone Demo
  • NonSecure Callback:
    void prvCallback( void )
  • Secure Calling Task:
TrustZone Demo Call Sequence
The MPU demo demonstrates how to use MPU to grant a task different permissions to various memory regions. The MPU demo consists of the following two tasks:
  • RW Task:
  • RO Task:
  1. Double click the FreeRTOS/Demo/CORTEX_MPU_M33F_Simulator_Keil_GCC/FreeRTOSDemo.uvmpw file to open it in the Keil uVision IDE. The Keil multi-project workspace FreeRTOSDemo.uvmpw contains a secure project (FreeRTOSDemo_s) and a non-secure project (FreeRTOSDemo_ns).
  2. Set the secure project as active by right clicking on "Project: FreeRTOSDemo_s" and selecting "Set as Active Project".
  3. Build the secure project by clicking "Project --> Build 'FreeRTOSDemo_s (FVP Simulation Model)'".
  4. Set the non-secure project as active by right clicking on "Project: FreeRTOSDemo_ns" and selecting "Set as Active Project".
  5. Build the non-secure project by clicking "Project --> Build 'FreeRTOSDemo_ns (FVP Simulation Model)'".
  6. Start the Debug Session by clicking "Debug -> Start/Stop Debug Session".
  • Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_MPU_M33F_Simulator_Keil_GCC/Config/FreeRTOSConfig.h. The constants defined in that file can be edited to suit your application. The following configuration options are specific to the ARM Cortex-M33 port:
