The 202406 release includes kernel support for Symmetric Multiprocessing (SMP) and Memory Protection Units (MPU), plus improved library IPv6 support. See the blog post.
Zynq, Zynq UltraScale+ MPSoC (64-bit ARM Cortex-A53 and 32-bit ARM Cortex-R5), Microblaze, PPC405 running on a Virtex4 FPGA, PPC440 running on a Virtex5 FPGA.
IA32 (32-bit flat memory model), Quark SoC X1000 (32-bit flat memory model), any x86 compatible running in Real mode only, plus a Win32 port. A port for the Linux Simulator is available as well.
GCC, Visual Studio 2010 Express, MingW, Open Watcom, Borland, Paradigm
Tricore, MICO32, Blackfin, Jennic, eZ80, SuperH and others.
Contributed Ports
Contributed ports are provided "as is" and are not supported directly.
