Renesas RZ/A1 (ARM Cortex-A9) RTOS Demo
Including FreeRTOS-Plus-CLI and FreeRTOS-Plus-FAT SL
Using ARM (DS-5) and IAR embedded compilers
Renesas Chips
This page documents a FreeRTOS demo application for the Renesas RZ/A1 embedded processor, which has an ARM Cortex-A9 core. Two projects are provided, allowing the demo to be built with both the IAR Embedded Workbench and ARM DS-5 embedded development tools. The demo targets the Renesas RZA1 RSK.
The demo uses:
  • The FreeRTOS Cortex-A9 kernel port for the ARM or IAR compiler (depending on the project file used)
  • Either the IAR Embedded Workbench or ARM DS-5 IDE (depending on the project file used)
  • The FreeRTOS-Plus-FAT SL ("S"uper "L"ean) DOS compatible FAT file system. [Note the FreeRTOS-Plus-FAT SL license is different from the FreeRTOS kernel license]
IMPORTANT! Notes on using the FreeRTOS Renesas RZ/A1 demo project
  3. Build Instructions (for both Embedded Workbench and DS-5)
The FreeRTOS zip file contains source code for all the RTOS ports and all the RTOS demo applications. Only a small subset of these files are required by the Renesas RZ/A1 demo. The Source Code Organization page describes the structure of the FreeRTOS zip file download, and provides information on creating a new RTOS project.
The ARM DS-5 Eclipse project file is located in the FreeRTOS/Demo/CORTEX_A9_RZ_R7S72100_IAR_DS-5 directory.
The IAR Embedded Workbench project file is located in the FreeRTOS/Demo/CORTEX_A9_RZ_R7S72100_IAR_DS-5/IAR" directory.
The DS-5 and IAR projects build the same RTOS demo application, and both include files that are contained in the /FreeRTOS-Plus directory (so the projects will not build if the /FreeRTOS-Plus directory has been deleted).
The Renesas RZ/A1 ARM Cortex-A9 Demo Application
Hardware and software set up
The demo presented on this page runs on the Renesas RZA1 RSK, but can easily be adapted to run on any development board that provides access to one UART and one digital output (preferably with an LED connected).
  • UART
    A UART is used for console IO, or a serial port loopback demo (depending on the build, see below). The download uses UART 2 for this purpose. If it is necessary to use a UART other than UART 2 then:
    • Modify the UART initialisation code contained in siochar.c to instead initialise whichever UART is to be used.
    • Modify the UART interrupt configuration, interrupt handling, and character output code located in serial.c to instead manage whichever UART is to be used.
  • LED digital output
    A digital output is used to toggle an LED. The download uses bit 10 of port 4 for this purpose. If it is necessary to use a different digital output then:
    • Edit the initialisation and management of the digital output code contained in LEDs.c to instead use whichever digital output is to be used.
The behaviour of the demo is defined by the following two constants:
  • mainCREATE_SIMPLE_BLINKY_DEMO_ONLY:
    mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is defined in main.c.
    mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is used to switch between a very basic 'blinky' demo, and a comprehensive test and demo application.
  • mainINCLUDE_FAT_SL_DEMO:
    mainINCLUDE_FAT_SL_DEMO is defined in main_full.c.
    If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0 then mainINCLUDE_FAT_SL_DEMO has no effect.
    If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY and mainINCLUDE_FAT_SL_DEMO are both set to 1 then FreeRTOS-Plus-FAT SL is used to create a RAM disk, and FreeRTOS-Plus-CLI is used to provide a command line interface through a UART. The CLI provides access to the file system.
    If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 1 and mainINCLUDE_FAT_SL_DEMO is set to 0 then the UART is used to run the COM test standard demo task - and a loopback connector (connecting pins 2 and 3) must be fitted to the UART port.
main_full() creates a comprehensive test and demo application that, when mainINCLUDE_FAT_SL_DEMO is also set to 1, demonstrates:
Using the RTOS CLI to access the FAT FS Connect to FreeRTOS-Plus-CLI though the UART using 115200 baud. Type 'help' in the CLI to see a list of the registered commands. Some commands are generic demonstrations, while others allow viewing and manipulation of the file system. This part of the demo is (at the time of writing) identical to that described on the FreeRTOS-Plus-FAT SL Win32 simulator demo page - where a video that shows the CLI being used can also be viewed.
Most of the other tasks created by the demo are from the set of standard demo tasks. These are used by all FreeRTOS demo applications, and have no specific functionality or purpose other than to demonstrate the FreeRTOS API being used and test the RTOS kernel port.
A 'check' task is also created. The check task periodically queries the standard demo tasks to ensure they are functioning as intended. The check task also toggles an LED to give a visual indication of the system status. If the LED toggles every 3 seconds then the check task has not discovered any problems with the executing demo. If the LED toggles every 200 milliseconds then the check task has discovered a problem in at least one task..
Build Instructions
Note that the IAR project references common files from both the /FreeRTOS-Plus and /FreeRTOS/Demo/Common directories, so the project will not compile if /FreeRTOS-Plus has been deleted.
  1. Open FreeRTOS/Demo/CORTEX_A9_RZ_R7S72100_IAR_DS-5/IAR/RTOSDemo.eww from within the Embedded Workbench IDE.
  3. Select "Build All" from the IDE's "Project" menu.
  6. Select "Download and Debug" from the IDE's "Project" window to download the built executable to the ARM Cortex-A9 and start a debug session.
Building and executing the demo application - DS-5
  1. Open DS-5 and either create a new workspace or select an existing workspace when prompted.
  3. In the Import dialog box, select "General->Existing Projects Into Workspace" then browse to and select the FreeRTOS/Demo/CORTEX_A9_RZ_R7S72100_IAR_DS-5 directory. A project called "FreeRTOS_Demo" will be visible.
  4. Ensure FreeRTOS_Demo is checked and that Copy Projects Into Workspace is not checked before clicking "Finish".
    Importing RTOS projects into ARM DS-5 Eclipse workspace
  6. Ensure the target hardware is connected to the host computer using an appropriate debug interface (D-Stream, U-Link, etc.).
  8. After the build completes, select "Debug Configurations..." from the IDE's "Debug" menu, and configure and run a debug configuration that is appropriate for your selected connection method (D-Stream, U-Link, etc.). The clickable screenshots below show a configuration that is using the D-Stream debugger.
    D-stream Cortex-A debug configuration D-stream Renesas RZ debug configuration Renesas debug using DS-5 from ARM
    Click Images to Enlarge
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_A9_RZ_R7S72100_IAR_DS-5/Source/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application.
This demo uses drivers provided by Renesas to configure the interrupt controller, and install application defined interrupts. The Renesas drivers require interrupt service routines (ISRs) to accept a uint32_t parameter, although the parameter is not actually used and can be ignored. The required ISR prototype is therefore:
    void Interrupt_Handler( uint32_t ulUnusedParameter );
The macros portYIELD_FROM_ISR() (or portEND_SWITCHING_ISR()) can be used to request a context switch from within an ISR. The following source code snippet is provided as an example. The example ISR uses a semaphore to synchronise with a task (not shown), and calls portYIELD_FROM_ISR() to ensure the interrupt returns directly to the task. (The function prvRXI_Handler() in the file serial.c provides another example.)
void Dummy_IRQHandler( uint32_t ulUnused )
    ( void ) ulUnused;
Information is provided on the Using FreeRTOS on ARM Cortex-A Embedded Processors page. This demo is configured to generate the tick interrupt from the OSTM0 peripheral.
