Cellular Interface Demo (Zero Touch Provisioning)
On this page:
1NCE is a global IoT Carrier that specializes in providing managed connectivity services for low
bandwidth IoT applications. In this demo, the 1NCE service (a 1NCE sim card + AWS IoT device
onboarding server) and a BG96 cellular module are used to demonstrate how to provision a device
with zero-touch and to connect to AWS IoT core. Refer to the
1nce blueprint for FreeRTOS and, in particular, to this
flow chart, to learn how the zero-touch-provisioning works.
Download the source code
The source code can be downloaded from the FreeRTOS labs or by itself through Github.
To clone using HTTPS:
git clone https://github.com/FreeRTOS/Lab-Project-FreeRTOS-Cellular-Demo.git --recurse-submodules
Using SSH:
git clone git@github.com:FreeRTOS/Lab-Project-FreeRTOS-Cellular-Demo.git --recurse-submodules
If you have downloaded the repo without using the --recurse-submodules
argument, you must run:
git submodule update --init --recursive
The demo project is called 1nce_bg96_zero_touch_provisioning_demo.sln
and can be found found on
Github in the following directory.
./Lab-Project-FreeRTOS-Cellular-Demo
├── lib
│ ├── backoff_algorithm ( submodule : backoffAlgorithm )
│ ├── cellular ( submodule : FreeRTOS-Cellular-Interface )
│ ├── coreMQTT ( submodule : coreMQTT )
│ ├── FreeRTOS ( submodule : FreeRTOS-Kernel )
│ └── ThirdParty
│ └── mbedtls ( submodule : mbedtls )
├── projects
│ ├── sim70x0_mqtt_mutual_auth_demo ( demo project for SIMCOM sim7080/sim7090 )
│ └── 1nce_bg96_zero_touch_provisioning_demo ( demo project for 1nce zero touch provisioning with BG96 )
└── source
├── cellular
│ └── ( code for adapting FreeRTOS Cellular Library with this demo )
├── coreMQTT
│ └── ( code for adapting coreMQTT with this demo )
├── FreeRTOS
│ └── ( code for adapting FreeRTOS with this demo )
├── mbedtls
│ └── ( code for adapting mbedtls with this demo )
├── main.c
├── cellular_setup.c
├── MutualAuthMQTTExample.c
├── demo_config.h
├── logging_levels.h
├── logging_stack.h
├── 1nce_zero_touch_provisioning.h
└── 1nce_zero_touch_provisioning.c
The following parameters in the cellular configuration,
cellular_config.h, must be modified for your network environment.
Configuration |
Description |
Value |
CELLULAR_COMM_INTERFACE_PORT |
Cellular communication interface make use of COM port on computer to communicate with cellular module on windows simulator. |
Your COM port connected to cellular module |
CELLULAR_APN |
Default APN for network registration. |
Specify the value according to your network operator. |
CELLULAR_PDN_CONTEXT_ID |
PDN context id for cellular network. |
Default value is CELLULAR_PDN_CONTEXT_ID_MIN. |
CELLULAR_PDN_CONNECT_TIMEOUT |
PDN connect timeout for network registration. |
Default value is 100000 milliseconds. |
Configure the MQTT broker
The configuration for connecting to a MQTT broker can be found in
"source/demo_config.h". Refer to the
documentation for
more information about the settings.
Reference the cellular module documentation for COM port settings. Update the
comm_if_windows.c if necessary.
"source/FreeRTOS/FreeRTOSConfig.h",
"source/mbedtls/mbedtls_config.h" and
"source/coreMQTT/core_mqtt_config.h" are configurations
for the corresponding sub-modules.
Build and run the 1nce zero-touch-provisioning demo
In Visual Studio, open the
1nce_bg96_zero_touch_provisioning_demo.sln project.
In this Visual Studio solution file, the macro USE_1NCE_ZERO_TOUCH_PROVISIONING
is
defined. Please look for #ifdef USE_1NCE_ZERO_TOUCH_PROVISIONING
in the source files
to see the difference in how a device using the 1nce service is provisioned. Otherwise, this demo
performs the same mutually authenticated MQTT operations as the other demos.
Generate a self-signed certificate and its private
key locally. Update
"source/demo_config.h" with the certificate and
private key. These are used to establish a TLS connection to the 1nce server. Note that the keys
are placed in a header file for demonstration purposes only; production devices should use secure
storage to store the keys.
Get the Access Point Name (APN) for your SIM card from 1NCE. Update CELLULAR_APN
in the file
"cellular_config.h" for BG96, and follow the steps in
"Configure the Application Settings" above to finish the rest of the configuration.
Compile and run.
