FreeRTOS MPS2 QEMU Demo (Arm Cortex-M3)
For both the IAR and arm-none-eabi-gcc compilers (makefile and Eclipse)
FreeRTOS on QEMU
This page documents a FreeRTOS kernel demo that targets the Arm Cortex-M3 mps2-an385 QEMU model. Preconfigured build projects are provided for both the IAR Embedded Workbench and arm-none-eabi-gcc (GNU GCC) compilers. The GCC project uses a simple makefile that can be built from the command line or the provided Eclipse CDT IDE project.
IMPORTANT! Notes on using the QEMU Cortex-M3 RTOS demo
See also the FAQ My application does not run, what could be wrong?, noting in particular the recommendation to develop with configASSERT() defined in FreeRTOSConfig.h and configCHECK_FOR_STACK_OVERFLOW set to 2.
The FreeRTOS distribution available from this website site contains the source files for all the FreeRTOS ports, and the projects for all the FreeRTOS demo applications. It therefore contains many more files than are required to use the Cortex-M3 mps2-an385 QEMU demo. See the Source Code Organization section for a description of the directory structure and information on creating a new FreeRTOS project.
The IAR Embedded Workbench for ARM workspace for the mps2-an385 demo application is called RTOSDemo.eww, and is located in the FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/iar directory.
The makefile that builds the project using the arm-none-eabi-gcc (GNU GCC) compiler, and the Eclipse project that builds the same makefile, are both located in the FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/gcc directory.
The mps2-an385 Arm Cortex-M3 QEMU Demo Application
The demo projects provide both the simple blinky and comprehensive test/demo configurations described on the FreeRTOS Demos Applications documentation page. Specific to the demo documented on this page, the "check" task periodically prints a message in the following format:
StatusMessageString : aaaa (bb)
Where StatusMessageString is a descriptive text string, aaaa is the RTOS tick count, and bb is the number of times the application detected interrupts becoming nested.
  1. Open FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/iar/RTOSDemo.eww from within the IAR Embedded Workbench IDE.
  2. Open main.c, and set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to generate either the simply blinky demo, or the comprehensive test and demo application, as required.
  3. Select 'Rebuild All' from the IDE's 'Project' menu, the RTOS Demo project should build without any errors or warnings. A successful build creates the elf file FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/iar/Debug/Exe/RTOSDemo.out.
    Note: If QEMU is already running the build will fail because QEMU prevents the generated elf file from being overwritten.
  4. Ensure QEMU is installed on your host computer.
  5. Start QEMU with the following command line, replacing [path-to] with the correct path to the RTOSDemo.out file generated by the IAR build.
    qemu-system-arm -machine mps2-an385 -cpu cortex-m3 -kernel [path-to]/RTOSDemo.out -monitor none -nographic -serial stdio -s -S
    QEMU command line
    Omit the "-s -S" if you just want to run the FreeRTOS application in QEMU without attaching the debugger.
  6. After the build completes, select 'Download and Debug' from the IDE's 'Project' menu. The IAR debugger should create a GDB connection to QEMU, start a debug session, and break on entry to the main() function.Note: Remember to kill the QEMU session when the debugging session ends, otherwise QEMU will prevent the executable image being overwritten the next time the IAR project is built - resulting in a linker error.
Building and executing the demo application - GCC Makefile
  1. Ensure both the arm-none-eabi-gcc compiler and GNU make utility are installed on your host machine.
  2. Open FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/main.c, and set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to generate either the simply blinky demo, or the comprehensive test and demo application, as required.
  3. Open a command prompt and navigate to the FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/gcc directory.
  4. Type "make" in the command prompt. The project should build without any compiler errors or warnings. Hint: Use the "-j" parameter to speed the compilation by using more cores on your host computer. For example, if you have four cores available you can build four C files at once by entering "make -j4". A successful build creates the elf file FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/gcc/output/RTOSDemo.out.
  5. Ensure QEMU is installed on your host computer.
  6. Start QEMU with the following command line, replacing [path-to] with the correct path to the RTOSDemo.out file generated by the GCC build.
    QEMU command line
  7. You can now use arm-none-eabi-gdb to start a command line debug session following below steps, although my preference is to start a graphical debug session, as described next for those using the Eclipse IDE.
    1. Start GDB: navigate to the path to RTOSDemo.out, and start ‘arm-none-eabi-gdb’.
      arm-none-eabi-gdb RTOSDemo.out
    2. Connect to QEMU: the default port for QEMU is 1234.
      (gdb) target remote localhost:1234
    3. Set breakpoints.
      (gdb) break main
    4. Start debugging.
      (gdb) continue
    5. Quit GDB.
      (gdb) quit
Building and executing the demo application - Eclipse
  1. Ensure the arm-none-eabi-gcc compiler and Eclipse CDT IDE are installed on your host machine. It may be necessary to install the GNU make utility separately if it is not included with Eclipse.
  2. Select 'Import' from the Eclipse 'File' menu, then 'Existing Projects Into Workspace' in the resultant window before clicking the Next button.
  3. In the next Window, select /FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/gcc as the root directory, check the FreeRTOSDemo project, and crucially ensure the "Copy projects into workspace" checkbox is unchecked, before clicking the Finish button to bring the project into Eclipse.
  4. Open main.c, and set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to generate either the simply blinky demo, or the comprehensive test and demo application, as required.
  5. Select 'Build All' from the Eclipse 'Project' menu. A successful build creates the elf file FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/gcc/output/RTOSDemo.out.
  6. Ensure QEMU is installed on your host computer.
  7. Open a command prompt then start QEMU with the following command line, replacing [path-to] with the correct path to the RTOSDemo.out file generated by the GCC build.
    QEMU command line
  8. Click the little arrow next to the green bug speed button, then select "Debug Configurations..." from the resultant menu.
  9. In the debug configurations window, select "FreeRTOSDemo Default" from under "GDB Hardware Debugging", then click the Debug button. The Eclipse debugger should create a GDB connection to QEMU, start a debug session, and break on entry to the main() function.
ARM Cortex-M3 RTOS port specific configuration
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
  • configTICK_RATE_HZThis sets the frequency of the RTOS tick interrupt. The supplied value of 1000Hz is useful for testing the RTOS kernel functionality but is faster than most applications need. Lowering the frequency will improve efficiency in production applications, but make the self checks within the comprehensive tests fail.
  • configKERNEL_INTERRUPT_PRIORITY and configMAX_SYSCALL_INTERRUPT_PRIORITY See the RTOS kernel configuration documentation for full information on these configuration constants. Note the QEMU model has 8 interrupt priority bits.
Unlike many FreeRTOS ports, interrupt service routines that cause a context switch have no special requirements, and can be written as per the compiler documentation. The macro portEND_SWITCHING_ISR() (or portYIELD_FROM_ISR() can be used to request a context switch from within an interrupt service routine.
