LIBRARIES
NOTE: The FreeRTOS Support for LoRaWAN demo project is in the FreeRTOS-Labs. It is fully functional, but undergoing optimizations or refactoring to improve memory usage, modularity, documentation, demo usability, or test coverage. It is available in the Lab-Project-FreeRTOS-LoRaWAN repository on GitHub separately from the main Labs Project Download.
FreeRTOS support for LoRaWAN Demo
As described above, Class A offers the most energy efficient mode of communication and results in the longest battery life. Both uplink and downlink messages can be either confirmed (an ACK is required from the other party) or unconfirmed (no-ACK required). The following diagrams Figure 3a and 3b shows the sequence of confirmed uplink and downlink. For detailed explanation, refer to Section 18 of LoRaWAN 1.0.3 specification.
Figure 3a - Uplink timing diagram for confirmed data messages (Source: LoRa Alliance) Click to enlarge.
Figure 3b - Downlink timing diagram for confirmed data messages (Source: LoRa Alliance) Click to enlarge.
The demo on this page describes a working example of Class A application. It spawns a Class A application task which sends an uplink message periodically following t link he fair access policy defined by the LoRaWAN regional parameters. Uplink messages can be sent either in confirmed or unconfirmed mode. After a successful uplink, the task waits for any downlink messages or other events from the MAC layer. It writes the frame payload and port received downlink to the console. If MAC layer indicates that there are further downlink messages pending or an uplink needs to be sent for control purposes, then it sends an empty uplink immediately. If a frame loss is detected by MAC layer, then it triggers a re-join procedure to reset the frame counters. Once all downlink data and events are processed, the task goes back to sleep until the next transfer cycle.
All events from MAC layer to application are sent using light weight task notifications. LoRaWAN allows multiple requests for the server to be piggy-backed to an uplink message. The responses to these requests are received by application in order using a queue. A downlink queue exists in case application wants to read multiple payloads received at once, before sending an uplink payload.
Low Power Mode
An important feature of Class A based communication is that application sleeps for most part of its lifecycle thereby consuming less power. Low power mode can be enabled for the demo using FreeRTOS tickless idle feature. Tickless idle mode can be enabled by providing a board specific implementation for portSUPPRESS_TICKS_AND_SLEEP() macro and setting configUSE_TICKLESS_IDLE to the appropirate value in FreeRTOSConfig.h. Enabling tickless mode allows MCU to sleep when the tasks are idle, but be waken up by an interrupt from the radio or other timer events.
Getting Started
Hardware needed for the demo described in this blog post:
Supported Platforms
Vendor MCU LoRa Radio Shield IDE
Nordic
NRF52840-DK
sx1262mb2cas
Segger Embedded Studio (SES)
STMicroeletronics
STM32-L4
sx1276MB1LAS
System workbench for STM32
Quick setup
Device Hardware Setup (Nordic NRF52840 + Semtech SX126x Mbed Radio)
The Nordic NRF52480 development kit is shown in Figure 4 and the Mbed shield for Semtech SX126x LoRa Radio transceiver is shown in Figure 5.
Figure 4: Nordic NRF52840-DK Board
Click to enlarge.
Figure 5: Semtech SX126x LoRa Radio transceiver
Click to enlarge.
The kit is compatible with the Arduino Uno version 3 standard, which makes it possible to stack the SX126x shield on top of it as shown in Figure 6. The Nordic MCU runs FreeRTOS and the LoRa MAC layer, and it communicates with the LoRa Radio transceiver over SPI, GPIO and Uart interfaces.
Figure 6 Nordic NRF52840-DK Board and Semtech SX126x LoRa put together
Click to enlarge.
Setup IDE
Download and view code
  • Setup SSH with Git repo.
  • Download the repository, along with the dependent repositories:
    git clone --recurse-submodules https://github.com/FreeRTOS/Lab-Project-FreeRTOS-LoRaWAN.git
  • FreeRTOS LoRaWAN implementation uses a slightly patched version of LoRaMac-Node v4.4.4. The patch is used to expose a radio HAL callback to notify of the interrupt events from radio. To apply the patch:
    cd Lab-Project-FreeRTOS-LoRaWAN
    git apply --whitespace=fix FreeRTOS-LoRaMac-node-v4_4_4.patch
  • Open Solution in the Segger Embedded Studio from the following path: demos/classA/Nordic_NRF52/classa_demo.emProject
  • Figure 7 Segger IDE showing ClassA Demo Project
    Click to enlarge.
    Device registration on The Things Network (TTN)
    Before end-device can communicate via The Things Network (TTN), follow the steps to register it with an application.
    Set up the Activation Credentials
    Over the Air Activation (OTAA) and Activation By Personalization (ABP) methods require Device EUI, Join EUI, and the necessary keys to be provisioned within the device. For a production use case, it is strongly recommended that you pre-provision these credentials using a secure element. To support pre-provisioned credentials, a user needs to provide an implementation of a secure element using the interface secure-element.h provided by the LoRaMac-node. Reference implementations for different secure elements can be found in the LoRaMac-node repository.
    The sample provided uses a software-based secure element. The credentials can be retrieved either from a memory location or flash using getter functions. By default, the sample hardcodes the credentials as const static variables. The steps below describe how to set the values of these variables.
    • Go to the file demos/classA/common/credentials.c and configure the global variables based on the activation type for the demo. NOTE: The parameters are provided as an array of hex values that represent bytes in big-endian ordering.
    • For Over The Air Activation (OTAA):
      • Set the variable devEUI to the 8 byte globally unique device EUI.
      • Set the variable joinEUI to the 8 byte join EUI.
      • Set appKey to the 16 byte pre-shared network key.
    • For Activation By Personalization (ABP):
      • Set variable joinEUI to the 8 byte join EUI.
      • Set the variables appSessionKey and nwkSessionKey to the 16 byte pre-shared session keys.
      • Set END_DEVICE_ADDR to the 24 bit NET ID which is pre-allocated.
        * @brief Device EUI needed for both OTAA and ABP activation.
        static const uint8_t devEUI[ 8 ] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
        * @brief JOIN EUI needed for both OTAA and ABP activation.
        static const uint8_t joinEUI[ 8 ] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
        * @brief App key required for OTAA activation.
        static const uint8_t appKey[ 16 ] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
    • Comment out or remove the line beginning with #error
      #error "Please configure DEV EUI, Join EUI and App key to run the demo using OTAA"
    Set up the LoRaWAN Region
    • Selecting a region for the sample will also select the frequency plan and other parameters for LoRaMAN, per LoRaWAN regional parameters guidelines. By default, the sample is set to connect to the US915 region
    • To select a different region for the sample, go to the class A task demos/classA/common/classa_task.c and update LORAWAN_REGION with the appropriate region type. Example:
    • #define LORAWAN_REGION ( LORAMAC_REGION_US915 )
    The list of enumerations for all regions can be found in the header file LoRaMac-node/src/mac/LoRaMac.h
    Build and Run your code
    • Connect your nrf52840-dk.
    • In the SES Build Menu, select Build classa_demo. Figure 8 below shows UART output in the IDE's debug terminal
    • In the SES Debug Menu, select Go. This will flash and run the demo in debug mode. There is a breakpoint at the beginning of the program. When you are ready, you can continue execution.
    • Figure 8 Segger IDE showing Build Complete
      Click to enlarge.
    Join the device
    • The device sends a Join request after initializing LoRaWAN stack.
      Figure 9 TTN Console showing end-device Join Request
      Click to enlarge.
    • The TTN console in Figure 10 shows a Join Accept is sent back from the LNS to the gateway, and then to the end-device.
      Figure 10 TTN Console showing end-device Join Accept
      Click to enlarge.
    • The end-device debug console in Figure 11 shows that the Join accept is received and the device completes the Join process successfully. The end-device gets the Device Address which is then used for all uplink and downlink communication.
      Figure 11 Segger IDE showing Join procedure complete with Device Address assignment
      Click to enlarge.
    Send Uplink
    LoRaWAN Class A communications allow a device to send uplink data at any time after a successful activation. However, devices that connect to a LoRaWAN network, should follow the duty cycle restrictions and fair access policy defined for a particular region. The policy limits the packet size or air time and the duty cycle allowed for transmission. Read more on duty cycle restrictions and the fair access policy here.
    The Class A demo task for FreeRTOS sends a periodic uplink of 2 bytes for a configured interval based on the duty cycle intervals. Here is a screenshot of the packets sent by the device and received on TTN:
    • As shown in Figure 12, device sends an uplink packet of 2 bytes 0xFEED every TX-RX cycle. Packets are sent as unconfirmed, which means ACK is not received for these packets. (Note: To change to confirmed mode, set the following config in demos/classA/common/classa_task.c).
      #define LORAWAN_CONFIRMED_SEND ( 1 )
      Figure 12 Segger IDE showing successful device uplink
      Click to enlarge.
    • The Figure 13 shows the packets received by the TTN console along with receive metadata such as gateway RSSI, SNR.
      Figure 13 TTN console showing end-device uplink along with receive metadata
      Click to enlarge.
    Receive Downlink
    For LoRaWAN Class A communications, a device opens receive slots only after every uplink message. The downlink packets can be queued for a device from the TTN console. The LNS selects the gateway for the device and queues the packet for a gateway. The device receives the downlink packet after it has successfully sent the next uplink packet.
    • To queue a downlink packet from TTN, Go to the Applications page, then click on your application. Click on the registered devices tab and select the device to which you want to send the downlink packet to. In the device page , under downlink tab, queue a payload for downlink as shown in Figure 14. (Figure 14 shows payload 2 bytes 0xC0DE queued on FPort 2 in unconfirmed-mode.)
      Figure 14 TTN console to schedule downlink
      Click to enlarge.
    • In Class A mode of operation, TTN network server schedules the downlink data and sends it to the device when it receives the next uplink packet from the device.
      Figure 15 TTN console to schedule downlink
      Click to enlarge.
    • The end-device receives the downlink data 0xC0DE on FPort 2 in one of the two receive windows after the next uplink, as shown in the Figure 16:
      Figure 16 Segger IDE showing downlink received for end-device
      Click to enlarge.
