taskENTER_CRITICAL_FROM_ISR()
taskEXIT_CRITICAL_FROM_ISR()
[RTOS Kernel Control]
task. h
UBaseType_t taskENTER_CRITICAL_FROM_ISR( void );
void taskEXIT_CRITICAL_FROM_ISR( UBaseType_t uxSavedInterruptStatus );
Versions of taskENTER_CRITICAL() and taskEXIT_CRITICAL()
that can be used in an interrupt service routine (ISR).
In an ISR critical sections are entered by calling taskENTER_CRITICAL_FROM_ISR(),
and subsequently exited by calling taskEXIT_CRITICAL_FROM_ISR().
The taskENTER_CRITICAL_FROM_ISR() and taskEXIT_CRITICAL_FROM_ISR() macros provide
a basic critical section implementation that works by simply disabling interrupts,
either globally, or up to a specific interrupt priority level.
If the FreeRTOS port being used supports interrupt nesting then calling
taskENTER_CRITICAL_FROM_ISR() will disable interrupts at and below the interrupt
priority set by the configMAX_SYSCALL_INTERRUPT_PRIORITY
(or configMAX_API_CALL_INTERRUPT_PRIORITY) kernel configuration constant, and leave
all other interrupt priorities enabled.
If the FreeRTOS port being used does not support interrupt nesting then
taskENTER_CRITICAL_FROM_ISR() and taskEXIT_CRITICAL_FROM_ISR() will have no effect.
Calls to taskENTER_CRITICAL_FROM_ISR() and taskEXIT_CRITICAL_FROM_ISR() are
designed to nest, but the semantics of how the macros are used is different to
the taskENTER_CRITICAL() and taskEXIT_CRITICAL()
equivalents.
Critical sections must be kept very short, otherwise they will adversely affect
the response times of higher priority interrupts that would otherwise nest.
Every call to taskENTER_CRITICAL_FROM_ISR() must be closely paired with a call to
- Parameters:
taskEXIT_CRITICAL_FROM_ISR() takes uxSavedInterruptStatus as its
only parameter. The value used as the uxSavedInterruptStatus parameter
must be the value returned from the matching call to
taskENTER_CRITICAL_FROM_ISR().
taskENTER_CRITICAL_FROM_ISR() does not take any
parameters.
taskENTER_CRITICAL_FROM_ISR() returns the interrupt mask state as it was
before the macro was called. The value returned by taskENTER_CRITICAL_FROM_ISR()
must be used as the uxSavedInterruptStatus parameter in the matching call
to taskEXIT_CRITICAL_FROM_ISR().
taskEXIT_CRITICAL_FROM_ISR() does not return a value.
/* A function called from an ISR. */
void vDemoFunction( void )
UBaseType_t uxSavedInterruptStatus;
/* Enter the critical section. In this example, this function is itself called from
within a critical section, so entering this critical section will result in a nesting
depth of 2. Save the value returned by taskENTER_CRITICAL_FROM_ISR() into a local
stack variable so it can be passed into taskEXIT_CRITICAL_FROM_ISR(). */
uxSavedInterruptStatus = taskENTER_CRITICAL_FROM_ISR();
/* Exit the critical section. In this example, this function is itself called from a
critical section, so interrupts will have already been disabled before a value was
stored in uxSavedInterruptStatus, and therefore passing uxSavedInterruptStatus into
taskEXIT_CRITICAL_FROM_ISR() will not result in interrupts being re-enabled. */
taskEXIT_CRITICAL_FROM_ISR( uxSavedInterruptStatus );
/* A task that calls vDemoFunction() from within an interrupt service routine. */
void vDemoISR( void )
/* Call taskENTER_CRITICAL_FROM_ISR() to create a critical section, saving the
returned value into a local stack variable. */
/* Calls to taskENTER_CRITICAL_FROM_ISR() can be nested so it is safe to call a
function that includes its own calls to taskENTER_CRITICAL_FROM_ISR() and
vDemoFunction();
critical section. Assuming interrupts were enabled on entry to this ISR, the value
saved in uxSavedInterruptStatus will result in interrupts being re-enabled.*/
