vTaskSetTimeOutState()
[Task Utilities]
task.h
void vTaskSetTimeOutState( TimeOut_t * const pxTimeOut );
vTaskSetTimeOutState() is used with xTaskCheckForTimeOut(). vTaskSetTimeOutState() is called to set the initial condition, after which xTaskCheckForTimeOut() can be called to check for a timeout condition, and adjust the remaining block time if a timeout has not occurred.
pxTimeOut   A pointer to a structure that will be initialized to hold information necessary to determine if a timeout has occurred.
An example is provided on the xTaskCheckForTimeOut() documentation page.
