xEventGroupGetStaticBuffer()
[Event Group API]
event_groups.h
 BaseType_t xEventGroupGetStaticBuffer( EventGroupHandle_t xEventGroup,
                                        StaticEventGroup_t ** ppxEventGroupBuffer );
Retrieve a pointer to a statically created event group's data structure buffer. It is the same buffer that is supplied at the time of creation.
xEventGroup   The event group for which the buffer will be retrieved.
ppxEventGroupBuffer   Used to return a pointer to the event group's data structure buffer.
pdTRUE if the buffer was retrieved, pdFALSE otherwise.
