xMessageBufferIsFull()
[RTOS Message Buffer API]
message_buffer.h
1BaseType_t xMessageBufferIsFull( MessageBufferHandle_t xMessageBuffer );
Queries a message buffer to see if it is full. A message buffer is full if it cannot accept any more messages, of any size, until space is made available by a message being removed from the message buffer.
  • xMessageBuffer
    The handle of the message buffer being queried.
If the message buffer is full then pdTRUE is returned. Otherwise pdFALSE is returned.
