xSemaphoreCreateRecursiveMutex
semphr. h
1SemaphoreHandle_t xSemaphoreCreateRecursiveMutex( void )
Creates a recursive mutex, and returns a handle by which the mutex can be referenced. Recursive mutexes cannot be used in interrupt service routines. configSUPPORT_DYNAMIC_ALLOCATION and configUSE_RECURSIVE_MUTEXES must both be set to 1 in FreeRTOSConfig.h for xSemaphoreCreateRecursiveMutex() to be available (configSUPPORT_DYNAMIC_ALLOCATION can also be left undefined, in which case it will default to 1).
Like non-recursive mutexes, recursive mutexes implement a priority inheritance algorithm. The priority of a task that 'takes' a mutex will be temporarily raised if another task of higher priority attempts to obtain the same mutex. The task that owns the mutex 'inherits' the priority of the task attempting to 'take' the same mutex. This means the mutex must always be 'given' back - otherwise the higher priority task will never be able to obtain the mutex, and the lower priority task will never 'disinherit' the priority. For more on the priority inheritance mechanism see the FreeRTOS Mutex documentation page
If the recursive mutex was created successfully then a handle to the created mutex is returned. If the recursive mutex was not created because the memory required to hold the mutex could not be allocated then NULL is returned.
1 SemaphoreHandle_t xMutex;23 void vATask( void * pvParameters )4 {5 Create a recursive mutex.6 xMutex = xSemaphoreCreateRecursiveMutex();78 if( xMutex != NULL )9 {10 /* The recursive mutex was created successfully and11 can now be used. */12 }13 }
