xTaskNotifyStateClear, xTaskNotifyStateClearIndexed
[RTOS Task Notification API]
task.h
1BaseType_t xTaskNotifyStateClear( TaskHandle_t xTask );
2
3BaseType_t xTaskNotifyStateClearIndexed( TaskHandle_t xTask,
4 UBaseType_t uxIndexToClear );
If a notification is sent to an index within the array of notifications then the notification at that index is said to be 'pending' until the task reads its notification value or explicitly clears the notification state to 'not pending' by calling xTaskNotifyStateClear().
xTaskNotifyStateClear() and xTaskNotifyStateClearIndexed() are equivalent macros - the only difference being xTaskNotifyStateClearIndexed() can operate on any task notification within the array and xTaskNotifyStateClear() always operates on the task notification at array index 0.
Backward compatibility information:
Prior to FreeRTOS V10.4.0 each task had a single "notification value", and all task notification API functions operated on that value. Replacing the single notification value with an array of notification values necessitated a new set of API functions that could address specific notifications within the array. xTaskNotifyStateClear() is the original API function, and remains backward compatible by always operating on the notification value at index 0 within the array. Calling xTaskNotifyStateClear() is equivalent to calling xTaskNotifyStateClearIndexed() with the uxIndexToNotify parameter set to 0.
  • xTask
    The handle of the RTOS task that will have its notification state cleared. Set xTask to NULL to clear the notification state of the calling task. To obtain a task's handle create the task using xTaskCreate() and make use of the pxCreatedTask parameter, or create the task using xTaskCreateStatic() and store the returned value, or use the task's name in a call to xTaskGetHandle(). The handle of the currently executing RTOS task is returned by the xTaskGetCurrentTaskHandle() API function.
  • uxIndexToClear
    The index within the target task's array of notification values to act upon. For example, setting uxIndexToClear to 1 will clear the state of the notification at index 1 within the array. uxIndexToClear must be less than configTASK_NOTIFICATION_ARRAY_ENTRIES. ulTaskNotifyStateClear() does not have this parameter and always acts on the notification at index 0.
If the task referenced by xTask had a notification pending, and the notification was cleared, then pdTRUE is returned. If the task referenced by xTask didn't have a notification pending then pdFALSE is returned.
1/* An example UART send function. The function starts a UART transmission then
2 waits to be notified that the transmission is complete. The transmission
3 complete notification is sent from the UART interrupt. The calling task's
4 notification state is cleared before the transmission is started to ensure it is
5 not co-incidentally already pending before the task attempts to block on its
6 notification state. */
7
8void vSerialPutString( const char * const pcStringToSend,
9 unsigned short usStringLength )
10{
11const TickType_t xMaxBlockTime = pdMS_TO_TICKS( 5000 );
12
13 /* xSendingTask holds the handle of the task waiting for the transmission to
14 complete. If xSendingTask is NULL then a transmission is not in progress.
15 Don't start to send a new string unless transmission of the previous string
16 is complete. */
17 if( ( xSendingTask == NULL ) && ( usStringLength > 0 ) )
18 {
19 /* Ensure the calling task's 0th notification state is not already
20 pending. */
21 xTaskNotifyStateClearIndexed( NULL, 0 );
22
23 /* Store the handle of the transmitting task. This is used to unblock
24 the task when the transmission has completed. */
25 xSendingTask = xTaskGetCurrentTaskHandle();
26
27 /* Start sending the string - the transmission is then controlled by an
28 interrupt. */
29 UARTSendString( pcStringToSend, usStringLength );
30
31 /* Wait in the Blocked state (so not using any CPU time) until the UART
32 ISR sends the 0th notification to xSendingTask to notify (and unblock) the
33 task when the transmission is complete. */
34 ulTaskNotifyTake( 0, pdTRUE, xMaxBlockTime );
35 }
36}
