FreeRTOS_shutdown()
FreeRTOS_sockets.h
1BaseType_t FreeRTOS_shutdown( Socket_t xSocket, BaseType_t xHow );
Disable reads and writes on a connected TCP socket. A connected TCP socket must be gracefully shut down before it can be closed.
  • xSocket
    The socket being shut down.
  • xHow
    Must be set to FREERTOS_SHUT_RDWR.
    FreeRTOS-Plus-TCP does not currently use the xHow parameter as it always shuts down both reads and writes. xHow is included to ensure the function prototype conforms to the expected Berkeley sockets standard, and for compatibility with future FreeRTOS-Plus-TCP versions which may accept other parameter values.
  • If the shutdown request was successful then 0 is returned. The shutdown being complete is indicated by FreeRTOS_recv() calls on the socket resulting in -pdFREERTOS_ERRNO_EINVAL being returned.
  • If xSocket is not a valid TCP socket then -pdFREERTOS_ERRNO_EOPNOTSUPP is returned.
  • If xSocket is a valid TCP socket but the socket is not connected to a remote socket then -pdFREERTOS_ERRNO_EOPNOTSUPP is returned.
Note that, because FreeRTOS does not implement errno, the behaviour in the presence of an error is necessarily different to that of connect() functions that are fully compliant with the expected Berkeley sockets behaviour.
The source code examples on both the Sending TCP Data and the Receiving TCP Data pages demonstrate a connected socket being shut down then closed.
