uxTaskBasePriorityGetFromISR
[Task Control]
task. h
UBaseType_t uxTaskBasePriorityGetFromISR( const TaskHandle_t xTask );
INCLUDE_uxTaskPriorityGet and configUSE_MUTEXES must be defined as 1 for this function to be available. See the RTOS Configuration documentation for more information.
Obtain the base priority of any task. The base priority of a task is the priority to which the task will return if the task's current priority has been inherited to avoid unbounded priority inversion when obtaining a mutex. This function is safe to use from within an interrupt service routine (ISR).
xTask Handle of the task to be queried. Passing a NULL handle results in the base priority of the calling task being returned.
The base priority of xTask.
