xTaskGetStaticBuffers()
[Task Creation]
task.h
 BaseType_t xTaskGetStaticBuffers( TaskHandle_t xTask,
                                   StackType_t ** ppuxStackBuffer,
                                   StaticTask_t ** ppxTaskBuffer );
Retrieve pointers to a statically created task's data structure buffer and stack buffer. These are the same buffers that are supplied at the time of creation.
xTask   The task whose buffers will be retrieved.
ppuxStackBuffer   Used to return a pointer to the task's stack buffer.
ppxTaskBuffer   Used to return a pointer to the task's data structure buffer.
