xMessageBufferGetStaticBuffers()
[RTOS Message Buffer API]
message_buffer.h
 BaseType_t xMessageBufferGetStaticBuffers( MessageBufferHandle_t xMessageBuffer,
                                            uint8_t ** ppucMessageBufferStorageArea,
                                            StaticMessageBuffer_t ** ppxStaticMessageBuffer );
Retrieve pointers to a statically created message buffer's data structure buffer and storage area buffer. These are the same buffers that are supplied at the time of creation.
xMessageBuffer   The message buffer whose data structure buffer and storage area buffer will be retrieved.
ppucMessageBufferStorageArea   Used to return a pointer to the message buffer's storage area buffer.
ppxStaticMessageBuffer   Used to return a pointer to the message buffer's data structure buffer.
